Set Enterprise Data
Mar 13th, 2008
IPCC Express premium - 4.0(5)
Hi, I have a question regarding the Set Enterprise Data Step. This works fine when passing a call to a contact service queue, and then onto an agent -> Enterprise Date gets shown in the Agent Desktop. It also works fine if I use a Call Redirect step to pass the call onto a preferred agent.
However : if I use a Call Consult Transfer step, then no Enterprise Data is shown in the Agent Desktop. Same problem when using the Connect Step without a Select resource. I don't want to use the redirect step because then I loose control over the call.
Any ideas why this happens with the Call Consult Transfer step ?
Many Thanks
Nik.
hadbou Wed, 03/19/2008 - 09:24
To resolve this issue, perform these steps:
Open a cmd prompt.
Run IPUpdate from C:\Program Files\cisco\desktop_config\util, and update the IP address.
If the procedure fails to update the IP address, perform these steps:
Go to C:\Program Files\Spanlink, and copy the entire folder to a safe location. Delete the Spanlink folder.
Go to Registry, and copy the HKEY_LOCAL_MACHINE\SOFTWARE\Spanlink hive to a safe location. Delete the Spanlink hive.
Re-run CRS setup.
nikolaas.noyez@... Thu, 03/20/2008 - 00:04
hadbou,
thanks for the reply... but I can't seem to find the \util directory, nor the IPUpdate tool. probably for another version of CRS ?
