Upgrading IAD from 12.3-14T5 to 12.4-15T
Mar 13th, 2008
Hi all,
Last night, we tried to upgrade our IAD from c2430-ik9o3s-mz.123-14.T5.bin to c2430-ik9o3s-mz.124-15.T.bin.
We first downloaded the new version via HTTP, assigned the boot system flash command, removed the old boot system flash command, and rebooted.
It took about about 10 minutes for it to come back up, and it reverted to the old version. consoled in, we receive:
%SYS-6-READ_BOOTFILE_SKIP: boot system flash:c2430-ik9o3s-mz.124-15.T.bin command is s
kipped
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
boot of "c2430-ik9o3s-mz.124-15.T.bin" using boot helper "flash:c2430-ik9o3s-mz.123-14
.T5.bin" failed
error returned: c2430-ik9o3s-mz.124-15.T.bin
loadprog: error - on file open
boot: cannot load "c2430-ik9o3s-mz.124-15.T.bin"
%RMON-5-FALLINGTRAP: Falling trap is generated because the value of cbQosCMDropBitRate
.1059.1061 has fallen below the falling-threshold value 0Creating CNF files
CNF-FILES: Clock is not set or synchronized,
retaining old versionStamps
%LINK-3-UPDOWN: Interface ephone_dsp DN 2.1, changed state to up
%LINK-3-UPDOWN: Interface ephone_dsp DN 4.1, changed state to up
%LINK-3-UPDOWN: Interface ephone_dsp DN 5.1, changed state to up
%LINK-3-UPDOWN: Interface ephone_dsp DN 6.1, changed state to up
%LINK-3-UPDOWN: Interface ephone_dsp DN 7.1, changed state to up
%LINK-3-UPDOWN: Interface ephone_dsp DN 8.1, changed state to up
%LINK-3-UPDOWN: Interface ephone_dsp DN 9.1, changed state to up
%LINK-3-UPDOWN: Interface ephone_dsp DN 10.1, changed state to up
kipped
.T5.bin" failed
We then deleted the new bin file, and transfered it over again using tftp with the same results.
Anyone run in to this issue before?
Andy
chrclark Fri, 03/14/2008 - 06:09
  • Cisco Employee,
It seems that the image file is possibly corrupted. First, I would download 12.4(15)T3 from CCO.
http://www.cisco.com/cgi-bin/Software/Iosplanner/Planner-tool/iosresult.cgi?get_crypto=&data_from=&hardware_name=IAD2430&software_name=IP%20SUBSET%2FIPSEC%2064BIT%2FFW%2FVOICE&release_name=12.4.15T3&majorRel=12.4&state=:HW:RL:SW&type=Early%20Deployment
Next, check the boot statements, and make sure that all of the old boot statements have been removed.
show run | incl boot
Hope this helps,
Chris
andrew-susag Fri, 03/14/2008 - 06:16
Thanks for the advice, I'll give it a try after 5 tonight. should I boot it to 12.4(15)T3 first, then boot it to 12.4(15)T? Or will 12.4(15)T3 act as an alternative? Our voice technician says he needs that ios version to utilize Call Manager.
Andy
andrew-susag Tue, 03/18/2008 - 05:37
I transfered up the release that you recommended but I got the same results. I'll attach the log. The current IOS on the IAD is was but in back in 2002, it's release c2430-ik9o3s-mz.123-14.T5.bin.
Maybe something is corrupt on the box itself?
chrclark Tue, 03/18/2008 - 05:55
  • Cisco Employee,
It looks like the flash file system is corrupted. I would format it and reload that image again.
Or try changing the boot statement to:
boot system flash flash:c2430-ik903s-mz.123-14.T5.bin
Yes -- the word flash is in there 2 times.
If that does not fix it, then you probably need to replace the IAD.
Chris
