Why 4507 logging rate-limited?
Mar 13th, 2008
We are not running any QoS policing on our 4507R's. However, we have recently noticed syslog messages being rate-limited, as below:
Syslog logging: enabled (0 messages dropped, 43 messages rate-limited, 0 flushes
, 0 overruns, xml disabled, filtering disabled)
Console logging: level debugging, 4756 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 21 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 4798 messages logged, xml disabled,
filtering disabled
Exception Logging: size (8192 bytes)
Count and timestamp logging messages: disabled
So my question is what mechanism is causing those 43 messages to be rate-limited? I'm having a hard time finding relevant documentation.
Overall Rating: 4 (1 ratings)
gkuzmowycz Thu, 03/13/2008 - 13:12
Thanks for the reply, Edison.
However, we have no rate-limiting set on logging, and the doc you pointed me to says the default is for no limiting. So I'm still wondering why the "sh logg" output I posted in my first message says 43 messages to syslog were rate-limited.
Edison Ortiz Thu, 03/13/2008 - 13:54
Correct. However, there are things sent to the console and/or buffer that are rate-limited independent of the rate-limit setting I described on the previous command.
ACLs for instance have a setting to limit the amount of messages that are sent to the logging service for processing. Perhaps those 43 messages were ACLs with a log option. I don't recommend changing the default setting on the ACL threshold but if you want to, take a read to this document:
http://www.cisco.com/en/US/docs/ios/12_4t/secure/configuration/guide/tsaclovw.html#wp1057179
HTH,
__
Edison.
gkuzmowycz Thu, 03/13/2008 - 14:53
Thanks. We've been testing ACL logging, so those may very well be the culprit.
