simonandorfi Fri, 03/14/2008 - 03:15
there are a few ways to manage:
- use a callmanager moh upload (ccm will transcode your file to the needed codes, but there is no way to adjust settings. Quality is not the best one:)
- If you have access to a G.729 IVR or IPCCX you can easily use a simple recording script to record new files.
- There is a G.729 codes on one of the Unity Software CD's. Maybe there is no encoder included.. but have a look.
- google for open g.729 project. There are a few shell script and cli-tools to convert.
hope this helps,
Simon
