switchover time etherchannel
Mar 13th, 2008
Hello ,
We have 2 Cat6509 switches witch are connected by an etherchannel.
When one port / link in the etherchannel is disconnected it takes 500 milisec to 1 sec
before the session is switched over to the other link in the etherchannel.
The requirments are 200 msec.
Can anyone tell me if that is possible between 2 Cisco 6509E?
Overall Rating: 5 (1 ratings)
Edison Ortiz Thu, 03/13/2008 - 11:03
  • Hall of Fame,
    Founding Member
The session is load-balanced amongst link members of the same etherchannel so there isn't any delay.
Are you talking about having multiple etherchannel bundles and if one etherchannel bundle fails, you want to speed up the process for the other etherchannel bundle to take over?
Can you post the portion of the config in question?
HTH,
__
Edison.
ekcdataip Fri, 03/14/2008 - 01:06
hello Edison,
In the attachment you can see a drawing of the test i've build. I simulate traffic with an Acterna tester on both sides (this is onlu one session). Between the two 6509's is a port-channel with 2x 1GE.
When i send traffic both the links are used. On Cisco_6509_1 there's output on Gi2/1 en on
Cisco_6509_1 there's output on Gi1/2. When i force a link break the switchover time is between the 500ms en 1s. When i put back the fiber i can see that it only takes about 20ms.
regards,
Pascal
this is a part of the config from the two switches:
switch1
interface GigabitEthernet1/1
description to g2/1 other
switchport
switchport trunk allowed vlan 600
switchport mode trunk
mtu 1528
load-interval 30
speed nonegotiate
no snmp trap link-status
lacp rate fast
channel-group 1 mode active
interface GigabitEthernet1/2
description to g2/2 other
switchport
mtu 1528
load-interval 30
speed nonegotiate
lacp rate fast
interface Port-channel1
description Port-channel to other 6509
switchport
mtu 1528
load-interval 30
speed nonegotiate
lacp fast-switchover
interface GigabitEthernet1/24
description to Acterna
switchport
switchport access vlan 600
switchport mode dot1q-tunnel
mtu 1528
load-interval 30
no cdp enable
switch2
interface GigabitEthernet2/1
description to g1/1 other
switchport
mtu 1528
load-interval 30
speed nonegotiate
lacp rate fast
interface GigabitEthernet2/2
description to g1/2 other
switchport
mtu 1528
load-interval 30
speed nonegotiate
lacp rate fast
switchport
mtu 1528
load-interval 30
speed nonegotiate
interface GigabitEthernet4/24
switchport
mtu 1528
load-interval 30
no cdp enable
Edison Ortiz Sat, 03/15/2008 - 09:27
  • Hall of Fame,
    Founding Member
Try changing the etherchannel mode from active/active to on/on. It does speed up the convergence.
HTH,
__
Edison.
ekcdataip Wed, 03/19/2008 - 05:42
when i switch to mode on, the channel is using PAGP and i want to use LACP. I also used the command channel-protocol LACP, but then the switch gives an error that its using PAGP.
(I want to use LACP because in the future i want to connect to an Alcatel switch)
Any other ideas?
kind regards,
Pascal
Edison Ortiz Thu, 03/20/2008 - 07:19
  • Hall of Fame,
    Founding Member
"On" uses unconditional etherchanneling. It does not use any intelligence such as PAgP or LACP.
Intelligent mechanism provided by PAgP and LACP does create a delay when forming an etherchannel. Your requirement demand faster convergence, therefore "On" should be your choice.
Don't use the channel-protocol command when configuring etherchanneling. Let the mode dictate the type of etherchannel you are going to configure.
active/active = LACP
active/passive = LACP
desirable/desirable = PAgP
desirable/auto = PAgP
on/on = unconditional
HTH,
__
Edison.
Kevin Dorrell Sat, 03/22/2008 - 02:57
  • Green, 3000 points or more
Edison is right that the fastest should be On/On. There is no channel negotiation to wait for. However, the negotiation should not cause you a problem. If the link is joining a channel it should not forward until any negotiation is complete anyway, so you will not notice any convergence problem. If the link is leaving a channel by failing, then it will not be able to negotiate anything anyway.
I wonder if you problem is not related to the ether-channel, but more related to the time it takes for the lower layers to detect and report the link failure. I wonder if there is a way to speed that up.
BTW, how are you measuring the convergence time? Is your measurment really measuring what you think it is measuring? Sorry, I know you posted a diagram, but I don't have Visio here.
Kevin Dorrell
Luxembourg
