abinjola Thu, 03/13/2008 - 08:11
  • Cisco Employee,
Active-host Limitations:
A host is considered active when any of the following statements are true:
. The host has passed traffic through the PIX Firewall during the time configured for the
xlate timeout interval
. The host has an established NAT/PAT translation through the PIX Firewall
. The host has an established TCP connection or UDP session through the PIX Firewall
. The host has an established user authentication through the PIX Firewall
Let me just re-quote from this link:
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/specs
.html#wp1150495
" In routed mode, hosts on the inside (Business and Home VLANs) count towards the limit
only when they communicate with the outside (Internet VLAN). Internet hosts are not
counted towards the limit. Hosts that initiate traffic between Business and Home are also
not counted towards the limit. The interface associated with the default route is
considered to be the Internet interface. If there is no default route, hosts on all
interfaces are counted toward the limit. In transparent mode, the interface with the
lowest number of hosts is counted towards the host limit. See the show local-host command
to view the host limits."
rasoftware Thu, 03/13/2008 - 08:19
Many thanks. Is there a command to see how many are in use? I've made a bit of a boob and ordered a load of 10 users ASAs.
Correct Answer
abinjola Thu, 03/13/2008 - 08:24
  • Cisco Employee,
show local-host
