6509 High CPU
I'm having a problem with one of our 6509s, the CPU on it constantly goes up to close to 100% for a minute and then drops back down to single digits (it happens every few minutes), it's not causing connectivity issues yet, but I'm worried that it eventually will. I can't really figure out what's going on, I'm pretty sure it's multicast traffic causing the problem though. I've attached a very basic diagram of our network.
Most of the multicast traffic would originate either from Core1 or Core2, although some multicast originates from either of the distribution switches or the access switches. All the interfaces and vlans are set up with sparse-dense mode and we're not using any RP's right now.
The switch that's having the cpu spikes is distribution 1...we're running EIGRP for routing.
Can anybody help me figure what's going on? Here is the output of show proc cpu when the cpu jumps up.
CPU utilization for five seconds: 95%/79%; one minute: 24%; five minutes: 27%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
86 3728919922187837326 0 14.58% 3.07% 4.77% 0 IP Input
170 109925716 998945240 110 0.57% 0.22% 0.23% 0 Port manager per
Thanks for any help!
Edison Ortiz Thu, 03/13/2008 - 12:00
Just the fact you are running multicast could be a factor for high CPU if not configured properly.
For further troubleshooting we need to see the switch configuration along with the show ip mroute and show version output.
Edison Ortiz Thu, 03/13/2008 - 13:01
You have a lot of multicast packets being switched in software, not a good thing.
Please post the output from typing show mls ip multicast
Edison Ortiz Thu, 03/13/2008 - 13:27
I highly recommend you configure a RP in your environment. From the show ip mroute it shows a concerning number of multicast groups being sofware switched.
Any group from that output without RPF-MFD, it's software switched which punts the process to the CPU.
With a RP design, the switch don't need to populate unwanted multicast groups on their table unless it has been requested by the clients they are servicing.
francisco_1 Thu, 03/13/2008 - 13:50
Is the dist1 switch only affected?
from your dist1 switch, which switch in your diagram is your layer 3 port-channel4 on the dist1 switch connected to since your dist1 is getting multicast traffic for different multicast groups on that port-channel. what you might want to do is limit the number of multicast or broadcast on that port-channel4.
Have you tried to use the storm-control broadcast level 70 command on the port-channel4 on the cat to limit increasing broadcasts/multicast?
That command will monitor broadcasts in one second intervals and once broadcast/multicast traffic load goes beyond 70% w/in that window the subsequent packets for the remainder of the 1s window will be dropped.
I would think this could help avoid excessive CPU. also just beware that the 6500 process broadcast in software that always affect the cpu unless you are usig catos.
Thanks ediortiz and francisco.
Po4 is the etherchannel to Core1...most multicast traffic would originate from core1 or core2 so it makes sense that alot of it is coming from Po4. Actually Dist1 is not the only switch affected, Core1 also has this problem but much less frequently.
My concern with storm-control is that this multicast traffic is very business critical, and a large burst resulting in dropped packets could be a big problem.
I have tried setting Core1 and Core2 to be RPs in the past, however for some reason when I do that the switch seems to flood some ports with multicast traffic on core1 even though they did not subscribe to it...the traffic exceeds 1GB/sec so some some of our servers (that do not subscribe to any multicast) had 1GB/sec of multicast hitting the port, making all the other apps on those servers drop. I probably have an error in that RP config, can you help me figure out what the problem with this config is?:
ip pim send-rp-announce Loopback0 scope 15 group-list 21
ip pim send-rp-discovery scope 15
access-list 21 permit
interface Loopback0
ip address
ip pim sparse-dense-mode
interface Loopback0
ip address
Thanks for all your help!
There are actually more then just those two switches participating in multicast...just about all the switches in our network need to listen get multicast data (the diagram I provided is just a very basic diagram with the most important components for this issue included).
I can probably still configure static RP instead of autoRP...let me see if I understand this right.
I have to run the these commands on every vlan and L3 interface that needs multicast data:
ip pim rp-address rp-address [access-list]
I have to switch every interface from sparse-dense mode to just sparse-mode
And I have to configure both core Lo0 interface to the same IP address with a /32 mask?
I still would prefer to use AutoRP as it would require alot less work...any reason why the config I provided ends up flooding ports with unwanted multicast traffic?
Edison Ortiz Thu, 03/13/2008 - 19:01
Going with Auto-RP is fine if you have a lot of switches and other L3 devices participating in your multicast domain.
I believe your config is fine up to the point where you have ip pim sparse-dense mode on the interfaces.
It will use sparse mode when the group has being mapped to a RP and dense when the RP isn't announcing such group. You have an ACL for the announcement so any multicast group not included on this announcement will run on dense mode, therefore you aren't gaining much on the RP configuration.
I recommend configuring sparse mode in all interfaces along with the config your provided and see if the behavior your experience before returns.
Just a note, you need the ip pim auto-rp listener in order to receive the .39 and .40 dense groups in all multicast devices.
The only multicast traffic on our network is in the 230.x.x.x and 231.x.x.x range...when this problem happened (the multicast flood on all interfaces), I ran a packet capture on one and I was receiving alot of 230.x.x.x packets even though that machine never subscribes to any multicast groups....and that address was running in sparse mode (since I had the acl there).
Right now, I'm running that config without the 230.x.x.x in the acl (only 231.x.x.x), and I DO get the 231.x.x.x packets on flooded to interfaces that don't need it, but the 230.x.x.x group is working fine (except the software routing problem which is causing high cpu utilization). There is very very little 231.x.x.x traffic so it's not really causing a problem that it's flooding all the ports (it's a test group right now).
I can try the sparse mode only on all interfaces..I'm just worried that come production hours, multicast packets will flood all the ports and it will take me longer to push out the old configs back to all the switches. I guess I can try to find a way to simulate alot of multicast traffic so I can test it off hours.
It's kind of late, I'm basically typing in my sleep so hopefully this post made sense. :)
francisco_1 Fri, 03/14/2008 - 00:40
make sure any layer 2 access switch receiving multicast are setup with IGMP snooping to help with multicast flood on all interfaces.
IGMP snooping can very effectively reduce multicast traffic from streaming and other bandwidth intensive IP applications. While a switch that does not understand multicast will broadcast multicast traffic to all the ports in a broadcast domain (a LAN), a switch using IGMP snooping will only forward multicast traffic to the hosts interested in that traffic. This reduction of multicast traffic reduces the packet processing at the switch (at the cost of needing additional memory to handle the multicast tables) and also reduces the workload at the end hosts since their network cards (or operating system) will not have to receive and filter all the multicast traffic generated in the network.
also on your vlans i think vlan 8 you have pim sparse-dense mode. like ediortiz said, you should use RP to use sparse-mode. much better to use instead of dense-mode.
also what you might want to do is to have ACL on your vlan 8 to limit the number of multicast address groups your switches are routing. what you can do it use ACL on the vlan8 for example and only accept multicast traffic on the addresses you use 230.x.x.x and 231.x.x.x range.
Good luck
Ok so here is what I did to test:
I set up RP's as described above for the 231.x.x.x group, I left the interfaces in sparse-dense mode so any other group would use dense mode. I then ran a test, listening to multicast traffic on group on the access switch plugged into the distribution switches, and publishing to the same group from a server plugged into Core 2.
As soon as I start the test, the CPU on Core 1 hits 100% and stays there till I end the test. I captured packets that were hitting the CPU and they were all multicast packets on the group. I verified the group was in sparse mode and there were no 231.x.x.x groups in dense mode. I run the same test on another group in dense mode and I do not get that CPU problem.
Any ideas why those packets hit the CPU like that?
b.julin Thu, 03/20/2008 - 12:22
The only time I've seen our 65xx with high IP-Input cpu was due to NAT, sometimes packet scans can saturate your tables, and the hold time on NAT translations is too high for some setups.
So if you have NAT on a segment of untrusted PCs that may scan around, try
ip nat translation tcp-timeout 1800
legerity1_2 Thu, 03/20/2008 - 14:04
I've taken a look at this and I'm beginning to wonder if this isn't non-rpf traffic on the L2 links.
Check this out:
Any way you could sniff the l2 port between dist1/2 to see if off tree traffic is reaching the "redundant" multicast router? Check to see if a (s,g) or (*,G) entry exists - if not, you may have just found the culprit.
I didn't sniff the traffic on the l2 port but I did run sh ip mroute sparse on the core 2 router (the multicast server in this case is located on core 1)...here is what I get:
(*,, 00:01:44/00:02:10, RP, flags: SP
Incoming interface: Null, RPF nbr
Outgoing interface list: Null
Also core 1 is the active vlan and core 2 has the standby vlan.
yeskriya007 Thu, 03/27/2008 - 21:42
Hi All,
I am facing a strange issue. Could be devaiting from the mulicast and all that stuff. My Sup 720's CPU utilisation is normally 30%, but when i run a show run / write memory command, the CPU spikes to >90% and then drops. Is this a normal behaviour?
Is there any document from Cisco, which says it could be normal.
I have put down the dir NVRAM: o/p here
Directory of nvram:/
1918 -rw- 397431 startup-config
1919 ---- 24 private-config
1920 -rw- 397431 underlying-config
1 ---- 48 persistent-data
2 ---- 4 rf_cold_starts
3 -rw- 0 ifIndex-table
1964024 bytes total (1563445 bytes free)
