Route based on protocol
Answered Question
Mar 13th, 2008
I think this is probably fairly straight forward but I can't find any example configs.
I'm looking to set my cisco 877 router to pass all http & FTP traffic onto another bradband router to reduce the loading on this broadband line. Is this easy to do? If so could someone give me some pointers?
Cheers,
Al
Correct Answer by Richard Burts about 9 years 3 months ago
Al
What you describe is fairly easy to do using the feature of Policy Based Routing. This link has information about how to configure PBR and should help you to get started with it:
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfpbr.html
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Thu, 03/13/2008 - 09:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Al
Rick
Richard Burts Fri, 03/14/2008 - 09:25
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Al
I am glad that you got it to work and that my suggestion was helpful. Thank you for using the rating system to indicate that your issue was resolved (and thanks for the rating). It makes the forum more useful when people can read about an issue and can know what successfully resolved the issue.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
