Blocking Harassing caller on CM/Unity 4.2
Mar 13th, 2008
We are running CM/Unity 4.2 with IPCC and receiving harassing caller that I am looking to block. What is the easiest way to do this. I am far from a voip system expert, I am learning as I go along. Any help would be greatly appreciated.
jason-calbert_2 Thu, 03/13/2008 - 12:33
  • Bronze, 100 points or more
Are you using H323 or MGCP gateways to route call?
If you are using H323 you can block this at the gateway. MGCP gateways can't block incoming numbers.
Jason
mbrooksbef Thu, 03/13/2008 - 12:40
we are using MGCP.
A much easier solution I brought up is to just i-divert the offensive calls when the called id shows up, but I cant seem to find where to specify the i-divert. The number that is getting the harassment has no voicemail, this way if they see the caller calling in, they can just dump them to a voicemail box and check it, or we can save the messages in case we want to pursue anything legal.
