ASA VLAN Question
massimiliano.se... Thu, 03/13/2008 - 10:53
  • Silver, 250 points or more
Every subinterface may have an own security level; sure you may have different security level for every interface.
I hope this helps.
Best regards.
Massimiliano.
No, it does not, when you set the security levels for sub interfaces, it does not have any interaction with the security level set on the physical interfaces. Routing is not possible between these interfaces unless you want this to happen then you use a certain command in the ios, if you need this command let me know and i will point you in right direction.
sundar.palaniappan Thu, 03/13/2008 - 14:38
  • Green, 3000 points or more
No,the security level of physical interface shouldn't affect the security level of sub-interfaces.
interface Ethernet0
nameif outside
security-level 0
no ip address
pixfirewall(config-if)# show run int e0.1
interface Ethernet0.1
vlan 2
nameif vlan2
security-level 25
no ip address
pixfirewall(config-if)# show nameif
Interface Name Security
Ethernet0 outside 0
Ethernet0.1 vlan2 25
Sundar
