VG224 line error on incoming FAX's
FAX's connected to VG224 receive line error on incoming FAX's. Outbouond FAX's complete successfully. This is an MGCP gateway I will include the MGCP config in this post
ccm-manager fallback-mgcp
ccm-manager redundant-host "Call Manager Publisher"
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server "Call Manager Publisher"
ccm-manager config
mgcp
mgcp call-agent "Call Manager Subscriber" 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp modem passthrough voip redundancy
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp timer net-cont-test 3000
mgcp sdp simple
mgcp fax rate 9600
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
m.batts Tue, 03/18/2008 - 09:13
  • Bronze, 100 points or more
You will need to post the config of the other gateway where the calls come in from.
They need to be setup the same for things to work
cheers
mark
