Ospf network Statement
Answered Question
I am just wondering if someone can guide me to a document or kindly explain.
If i have 2 networks say 10.10.10.0 255.255.255.0 and 192.168.10.0 255.255.255.0
then under ospf i should have the statements like this
router ospf 1
network 10.10.10.0 0.0.0.255 area 0
network 192.168.10.0 0.0.0.255 area 0
BUT...
if i put
router ospf 1
network 0.0.0.0 255.255.255.255 area 0
then would both the above are same or not. I was told they are same. I have been searching the website but cannot get the concept or a document which can explain...
Correct Answer by Edison Ortiz about 9 years 4 months ago
They are not the same.
The first one will only enable OSPF on interfaces belonging to subnet 10.10.10.0/24 and 192.168.10.0/24
The second one will enable OSPF on any interface in the router. If you were to create a loopback interface, this interface will also be included into OSPF and this can cause some problems if you did not intend to do so.
The network 0.0.0.0 255.255.255.255 area 0 is basically telling the router to enable OSPF on any interface that this router has. Not a recommended solution on production environment.
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Thu, 03/13/2008 - 10:37
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
