MGCP Gateway Unregistered CCM 6.1
Answered Question
Mar 13th, 2008
In our CCM 6.1 enviroment we have a problem with the MGCP gateway. When you look in the CCM you see that it is Unregistered.
Screendump CCM:
Product = Cisco MGCP E1 Port
Gateway = SGS-HR-GW1
Device Protocol = Digital Access PRI
Registration = Unregistered
IP Address = 10.7.0.20
End-Point Name = S0/SU0/[email protected]-HR-GW1
But when you look on the gateway it looks okay for me:
SGS-HR-GW1#sh ccm
MGCP Domain Name: SGS-HR-GW1
Priority Status Host
Primary Registered SGS-fn (10.7.0.10)
First Backup None
Second Backup None
SGS-HR-GW1#sh mgcp
MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE
MGCP call-agent: SGS-fn 2427 Initial protocol service is MGCP 0.1
Is there a config faillure ?
The problem starts with changing the IP address of the gateway, so I bring it back to the old IP address but the problem is still there.
Regards , Rene
Correct Answer by Jaime Valencia about 9 years 4 months ago
the sh ccm on a GW does not necessarily means the GW is registered, it only means the signaling at port 2428 is working fine. that is the keepalive port
verify that the MGCP call agent statements is looking at the right server, that the domain name under CCM is the hostname + domain (if configured)
try a no mgcp / mgcp
try deleting and readding the GW under the CCM config
javalenc
if this helps, please rate
Overall Rating: 5 (2 ratings)
Correct Answer
Jaime Valencia Thu, 03/13/2008 - 12:03
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
r.vanschendel Fri, 03/14/2008 - 05:36
***deleting and readding the GW under the CCM config***
that was the solution.
Thank you very much.
auppal Thu, 03/13/2008 - 19:34
  • Cisco Employee,
this looks like a domain name mismatch. Can you attach deb mgcp pack and bounce the mgcp and collect the logs
