AXL Serviceablility PerfmonListCounter - No Handler found
Mar 13th, 2008
I'm new to AXL Serviceability - has anyone made the Perfmon stuff work? I keep getting an error: No Handler found for PerfmonListCounter
I've tried a variety of SOAPAction header values but I still get the error. Besides what's below, I've tried
"http://schemas.cisco.com/ast/soap/action/#PerfmonPort#PerfmonListCounter"
"http://10.10.10.12:8443/perfmonservice/services/#PerfmonPort#PerfmonListCounter"
"http://10.10.10.12:8443/perfmonservice/services/PerfmonPort"
The request looks like this:
POST /axl/ HTTP/1.0
Host:10.10.10.11:80
Authorization: Basic ZGV2Y2VydDpzaWx2ZXJiYWNr
Accept: text/*
Content-type: text/xml
SOAPAction: "CUCM:DB ver=6.0"
Content-length: 496
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <SOAP-ENV:Body SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"> <q1:PerfmonListCounter xmlns:q1="http://schemas.cisco.com/ast/soap/"><Host xsi:type="xsd:string">10.10.10.12</Host></q1:PerfmonListCounter></SOAP-ENV:Body> </SOAP-ENV:Envelope>
pklos Fri, 03/14/2008 - 06:47
  • Silver, 250 points or more
To get handler you need to execute PerfmonOpenSession. Then you can add counter using PerfmonAddCounter.
regards,
PK
caholman Fri, 03/14/2008 - 06:58
Thanks, I will try that. One quick question is that the documentation claims you can use either single transaction or session-based collection (page 2-9 in AXL Serviceability API Dev Guide). I was attempting single transaction. Is the documentation not correct, and single-transaction method is not available ?
pklos Fri, 03/14/2008 - 08:15
You wanted to do PerfmonListCounter, but no counters was declared. So, ccm cannot list them.
regards,
PK
caholman Fri, 03/14/2008 - 09:31
The docs say PerfmonListcounter soap operation returns a list of all objects, and only takes Host as a parameter. Supposedly you can use it to list everything available, but not to select a certain counter. This is from 6.0(1) CUCM Developers Guide.
Have you used other PerfmonPort operations successfully? I value your feedback on PerfmonPort.
