Log-Entry: 'Warning: LDAP: query accept could not be found'
Mar 13th, 2008
I found many entries like this:
Thu Mar 13 12:45:30 2008 Warning: LDAP: query accept could not be found
in our log 'mail.current'.
We don't use LDAP (anymore). Where do I have to check if we have missed something what should be de-activated?
In the GUI 'System Administration', 'LDAP' I have the following entry:
Server Profile Host Name Port Queries
Profilename 1.2.3.4.,1.2.3.5 389 None configured
How can we prevent this warning-entries in the logfile?
kluu_ironport Tue, 03/18/2008 - 20:40
On the GUI interface, go to "Network > Listeners".
Select the inbound listener. At the bottom, make sure the LDAP queries are all set to None. You may also want to delete your ldap profiles if you're not using them anymore. "System Administration > LDAP"
If that doesn't address the warnings, contact Technical Support so they can further investigate it.
Pat_ironport Tue, 03/18/2008 - 22:11
Thank you for the detailed instructions!
I have doublechecked "make sure the LDAP queries are all set to None". They really are all unchecked.
For a little test, I have re-actived the accept-query for our AD.
If I do that, all this Warnings are gone.
If a uncheck the accept-query (just leave the LDAP-profile), the Warnings are back.
And you are right, if I delete the entire LDAP-profile, the Warnings are gone too.
