Request of printer authentication ???
Mar 13th, 2008
I was asked to authenticate by means of a ACS all the PCs, In order to carry out this requirement I had to configured the switch's port. However now I was asked to athenticate printers by means os ACS and the printers will be moved frequently.
Is is possible to authenticathe printers with this requirements?
Jagdeep Gambhir Fri, 03/14/2008 - 05:44
  • Red, 2250 points or more
You need to set up MAB "Mac authentication bypass" on switch.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_37_se/configuration/guide/sw8021x.html#wp1205506
----------Commands Required on Switch--------------
aaa new-model
aaa authentication dot1x default group radius
dot1x system-auth-control
radius-server host
radius-server key
config t
interface
switchport access vlan
dot1x port-control auto
dot1x mac-auth-bypass
dot1x timeout quiet-period 15
dot1x timeout tx-period 3
dot1x reauthentication
~JG
Do rate helpful posts
