local alarm on E1/T1 card
Mar 13th, 2008
Hi, I have a VWIC2-1MFT-T1/E1 card on 2801 router with orange led of local alarm active.
What this means? What is the cause of this alarm?
I try to find some docs about E1/T1 alarm but I don't find anything.
Thanks Enrico.
Paolo Bevilacqua Thu, 03/13/2008 - 14:48
Do do not use colors to judge alarms because these can change from a model to another.
Do "show controllers E1" and it will tell you everything about.
