no access by GUI CME 4.0 ?????
Answered Question
Mar 13th, 2008
I set the access by GUI option, I load the files in the flash and also I set the commands required to have access. When I tried to access by http://10.10.10.1/ccme.html the main page is displayed buy I have no access to the options, If I access by http://10.10.10.2/WEB (unity access) I have complety access to the options.
In other equipments where there is no unity installed if a access by http://10.10.10.1/ccme.html the main page is displayed buy I have no access to the options so I can not make any changes by the GUI
I have checked if all the files required are in the flash and they are.
any reason o somethingis left???
Correct Answer by dboutieller about 8 years 8 months ago
If you copied the files to the flash using a SANDISK reader plugged into your laptop, make sure that the files that are used for displaying the page are lowercase. There is a bug in microsoft that causes some of the files to be changed from lowercase to upper case when you do a copy and paste. Here are a few files in particular that are affected by it:
dom.js
Make sure these files are lower case. You can change them through the command line by doing a "rename flash:oldfilename newfilename"
See if this is the root of your problems
Overall Rating: 4.5 (2 ratings)
Paolo Bevilacqua Fri, 03/14/2008 - 07:21
  • Hall of Fame,
    Founding Member
Are you using the mandatory IE6? Have you enabled javascript ?
If you have coped the files in a directory, include that in "ip http path ...".
filiberto.aguirre Fri, 03/14/2008 - 12:29
I have already set
ip http server
no ip http secure-server
ip http path flash:
telephony-service
web admin system name cisco password cisco
dn-webedit
time-webedit
what I don't understand is why I have complete access using the path for unity express http://10.10.10.2/WEB but I have no access if I try http://10.10.10.1/ccme.html
(the main page is display with the options but I have no access).
uddinabu1 Sun, 07/06/2008 - 08:09
I am having same kind of problem but with Cisco Unity Express GUI is not working for me, CME GUI is working fine.
Thanks in advance for any helpfull idea!
filiberto.aguirre Tue, 03/18/2008 - 14:24
I have already anabled javascript but the result is the same. Which other options should I check in the browser? If thw browser is the problem why I can access all the options with the Unity express's GUI?????
Correct Answer
dboutieller Mon, 07/07/2008 - 09:33
dom.js
filiberto.aguirre Mon, 07/07/2008 - 09:50
Hi dboutieller,
I haven't realized of that difference, I have just checked those files and you are right!!!
I'm going to make those changes you recomend.
I really appreciate your time for answering .
filiberto.aguirre Thu, 07/10/2008 - 15:50
Hi dboutieller
I have just made the changes, now I CAN ACCESSS via gui to all option !!!!
A lot of thanks !!!
