Extension Mobility log out error CM6.1
Mar 13th, 2008
I have just configured Extension mobility on CM 6.1 and every once and a while I receive an error of "[6]-database error" when someone logs out. When this does happen I am only able to fix the problem by deleting the phone and reinstalling it in CM. I have tried to reset the EM service but because this is a production server I have not gone any farther with resetting services.
Has anyone seen this before and if so does anyone know of a fix for this.
Rob Huffman Thu, 03/13/2008 - 21:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Devin,
I would open a TAC case for this one. There are a number of bugs (usually EM Login) that give this error "[6]-database error". Here are three of them ;
CSCsg73474
CSCsd27551
CSCsi35186
CSCsg73474
Extension Mobility logins fail with an Error 6 Database failure.
Conditions:
Already running a CallManager version with the fix for CSCsd27551 (5.0(4)ES1
and later).
Workaround:
1. Restart the publisher to recover temporarily.
2. Contact the TAC engineer to follow the steps in "Workaround" enclosure to
workaround the problem without rebooting the server.
1st Found-In
5.0(4)
5.0(4.1101.2)
Fixed-In
5.0(4.2137.1)
5.1(1.3106.2)
5.1(1.3106.5)
5.1(1.3107.1)
5.1(1.9131.47)
5.1(2.1000.11)
6.0(0.9901.233)
6.1(1.1000.11)
Hope this helps!
Rob
Tommer Catlin Fri, 03/14/2008 - 09:34
  • Green, 3000 points or more
I had this problem also in 6.0. Check your RTMT and that you do not have any dbreplication errors. If you do, then get on the phone with TAC.
devin-chamberlain Fri, 03/14/2008 - 09:52
This may be a dumb question but where would I find the dbreplication errors in the RTMT?
Tommer Catlin Fri, 03/14/2008 - 10:01
It would be in the callmanager log files (application, system, etc)
