Strange issue with Voice Gateway
Mar 13th, 2008
Currently I have a Voice Gateway on one of my sites that connects to a PABX via E1 connection. The Voice Gateway is then connected to the WAN with connects it to other remote sites.
The Voice Gateway has VOIP dial-peers configured that were meant to forward voice traffic to other remote sites. However, it seems that when we try to dial those numbers, it is coming up with a 'congestion' message on the phone. Also when you do a show call active voice brief, the following is the result ..
39F3 : 27409 948401910ms.2 +-1 pid:100 Originate 100555 connecting
dur 00:00:00 tx:0/0 rx:0/0
IP 0.0.0.0:0 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 pre-ietf
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
It keeps showing up as g729r8 pre-ietf even though I've not specified that in the configuration. Calls from other remote sites work with the same configuration.
Any ideas?
Overall Rating: 5 (1 ratings)
marahman78 Fri, 03/14/2008 - 03:27
Put the following commands in your local interface of remote voice gateway
interface FastEthernet0/0 --> Local Interface
h323-gateway voip interface
h323-gateway voip bind srcaddr
Also put the following commands on remote voice gateway
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service voip
Steven Landon Sun, 03/16/2008 - 08:09
Is the phone with the message connected to a call manager? Congestion is a message that displays only when CAC has rejected the call.
Have you properly configured locations for your dial plan?
alexwzh Sun, 03/16/2008 - 16:36
Issues have been fixed from the previous post. Thanks everyone for your help.
