Port Security on cat6500
Mar 14th, 2008
i configure port security mac-address sticky on a cat6500, but i cann hit the global command " clear port-security sticky interface nr access"
Thanks for any response
Alain
Jagdeep Gambhir Fri, 03/14/2008 - 06:04
  • Red, 2250 points or more
Alain,
The clear port-security sticky is available only on the "smaller" platforms (2940, 2950, 2955, 2960, 2970, 3550, 3560, 3750, but not on the higer end platforms, such as the Cat4500 and Cat6500.
The reason not to include this command was "clear" command is to be used for dynamic addresses only. Any configured addresses should be cleared via the [no] form of the corresponding commands."
~JG
Do rate helpful posts
