Conference disconnect at CM Fallback
Mar 14th, 2008
In case of SRST, an active Conference Call is disconnect even if the ConfBridge is configured on the Gateway ?
Is that true ??
Situation :
One Publisher and on VG with SRST at the Remote Side. A Conference Call is established at the Remote Side. The WAN-Link to the Headquarter is disconnected.
Than the Conference calls where disconnected.
Can i solve this Problem ?
Thanks for Help
m.batts Tue, 03/18/2008 - 09:09
  • Bronze, 100 points or more
you could try the command
voice service voip
h323
no h225 timeou keepalive
The reason the calls are disconnect is because there tcp connection was lost which causes the calls to drop.Not sure if this will work for conferencing but you could give it a try.
