Upgrading ACS Software
We are currently running version 4.1.1.23 on our ACS appliances (the actual appliances, not a Windows or UNIX box). I would like to upgrade them to the lastes version, which is now 4.2.0.124 (although, since that is so new, I'd be happy with 4.1.4.13). However, I cannot find the base install for any of these versions, 4.2.0 or 4.1.4.
On the download site, it only has patches, not the full base image. Where can I get the full version upgrade?
Thanks.
Jagdeep Gambhir Fri, 03/14/2008 - 06:38
  • Red, 2250 points or more
ACS software's are not available on CCO and you need to open a TAC case inorder to get it.
~JG
Do rate helpful posts
