03-14-2008 07:17 AM
I deployed WAAS into our network with WAFS. Everything sims to work OK but on
INFO level I have notification:
INFO Host 1.1.1.1:139 was not discovered, bypass period: 60 sec, number of events: 1, reason: digital signatures are required by server
Somethimes it is port 445.
It is strange becouse this server is domain controller and I don't have another errors and everything - file servers, preposition to much more servers works.
Do anybody now what this info means ?
thanks in advance
Solved! Go to Solution.
03-14-2008 08:27 AM
Hey,
The reason that you are getting these messages is that by default, Windows AD servers have digital signatures enabled which prevent "caching" of the files (man in the middle). This is by design and these messages can be ignored for domain controllers. We still accelerate sessions to these servers via TFO/DRE/LZ, however they are not accelerated via the CIFS adapter (WAFS). Digital Signatures can be disabled via the registry, however, most sysadmins leave the AD servers as enabled and disable digital signatures if needed on the dedicated file servers for CIFS acceleration.
Hope that helps,
Dan
03-14-2008 08:27 AM
Hey,
Hope that helps,
Dan
