9@ route pattern
Mar 14th, 2008
hi Guys,
I am on 5.1 and have a problem for a site in North America.When using the 9@ route pattern users are unable to make outgoing calls(your call cannot be completed as dialled) yet when pattern is changed to 9! it works fine....Any thoughts much appreciated !!!!!
chris.mann Fri, 03/14/2008 - 08:00
What kind of filters do you have on your 9.@ pattern?
Steellllllllll0 Fri, 03/14/2008 - 08:04
I do not have any filter set....it is greyed out so cannot make any changes...
Jaime Valencia Fri, 03/14/2008 - 18:12
  • Cisco Employee,
  • Hall of Fame,
    2011
is that the only pattern you have?
is it 9.@ with discard predot?
after what digit do you get the message?
i assume you've already checked the CSS and partitions and that the phones are able to reach the 9.@
also what are you trying to dial when you get the message?
javalenc
Steellllllllll0 Mon, 03/17/2008 - 04:32
This is not the only pattern i have as we have multiple remote sites on the CCM.
The pre-dot is not done on the route pattern itself but on the route list instead.
When pressing any digit after the 9 the pattern is not being matched and the annunciator kicks in.
All CSS and Partitions have been checked to ensure the gateway has access....thanks!!
Jaime Valencia Mon, 03/17/2008 - 09:27
  • Cisco Employee,
  • Hall of Fame,
    2011
Try using the DNA tool to simulate the call, it will tell you what the CUCM thinks about the routing and what its doing
in some cases the cache is not refreshed and some old stuff remains in there, have you tried a reboot?
javalenc
if this helps, please rate
