03-14-2008 08:22 AM - edited 03-05-2019 09:45 PM
I recently purchased a laptop without a DB9 and do work frequently with Cisco routers. Is there a method to connect to a console port on a router without a DB9 port on my laptop?
Solved! Go to Solution.
03-14-2008 08:43 AM
Yes, visit a computer shop and purchase a USB to RS232C Serial Adapter Cable. I use ATEN and I have it for 3 years http://www.techbuy.com.au/p/28655/USB/ATEN/UC-232A.asp
Dandy
03-14-2008 08:43 AM
Dandy
03-14-2008 09:10 AM
Thats what I was thinking but I was hoping there was a way to connect directly from my Ethernet connection. Thanks.
03-14-2008 03:17 PM
Dude,
You will need console access first before you can configure the router to have network access.
