ACE - Disk0: Full
Mar 14th, 2008
I'm running a capture in on 2 interfaces in an ACE module context. I can see from the the dir command that there is only 1024K free left.
Is there any way to allocate more menory to that context so i can increase the the catpure buffer size which is currently limited to 1024K since I have to save it to disk0: ?
Overall Rating: 4 (1 ratings)
Gilles Dufour Sat, 03/15/2008 - 12:15
the disk0: is not virtualised.
So, if there is onl 1024k left it means the space is being used by other files in other contexts.
You'll have to make space if you need more memory.
deephazz02 Wed, 03/19/2008 - 05:33
Thanks for the answer.
I'll try to find out what's using that disk space.
