03-14-2008 08:31 AM - edited 03-05-2019 09:45 PM
I am trying to find this show command, which would give me Source and Destination ip address on a PTP link. It would also show me how much bandwidth they were using. Ideas?
Solved! Go to Solution.
03-14-2008 08:36 AM
Daniel
If you have configured NetFlow on the interface then you could use the show ip cache flow and get source and destination address and bandwidth usage.
Rick
03-14-2008 08:36 AM
Daniel
Rick
03-14-2008 08:45 AM
Thanks that was it, what is the difference between 3694 and 76k for the packets category?
03-14-2008 08:50 AM
Daniel
The packets category is a count of the number of packets. So someone transmitted 3694 packets and someone transmitted 76k packets.
Rick
