CUE 2.3 Voicemail Time Stamps an hour behind
Mar 14th, 2008
Running 12.4(11)T / CME 4.0(2) with CUE 2.3 on a 2821. The time stamps when a voicemail is left on the system is an hour behind apparently still on CST. Not sure how to change it. I am using the default gateway ip for the service engine as the NTP server in the GUI.
Thanks for your help
chrclark Fri, 03/14/2008 - 10:56
The final DST fixes for CUE were integrated into 2.3.4. Is that the version you are running? Or an earlier version?
keith.k.quaye Fri, 03/14/2008 - 11:01
I am running the earlier version apparently
Voice Mail (Voicemail application) 2.3.3
