WAAS WAE Inline Vlans
Mar 14th, 2008
Switch with trunk to router, whith the wae inline between them I cannot get between vlans, from the wan side I can get to all resource, Any ideas what to configure or look at
dstolt Sat, 03/15/2008 - 19:27
  • Cisco Employee,
Are you trying to only intercept one VLAN or all the VLANs? You can configure this on the inline card's interface or in the CM GUI under the Interception section for that device.
Dan
r-bjorge Fri, 06/06/2008 - 17:05
Version 13 got pulled - Upgraded to 17 and then it worked
