03-14-2008 10:06 AM - edited 03-13-2019 05:04 PM
I am getting reports from people in our offices that all of a sudden their phone goes blank which in turn causes the PC connected to the phone to loose connectivity. Here is what they have told me they do. They connect the PC directly in to the wall jack that the phone was connected to and the PC connects. They then take another phone and connect it to the jack in question and that phone works. They then take the phone in question and connect it to another jack and it works again. So they that the original phone and reconnect it to the original jack in it still will not work. I checked the interface for errors and there are none. Now I am being told it is happening and another location. I cannot confirm what they are telling me but I don't think they are misleading me...but this makes no sense to me. Has anyone seen or heard of anything like this?
Here is some phone info.
MAC Address XXXXXX
Host Name SEPXXXXXX
Phone DN XXXXXX
App Load ID jar41sccp.8-3-2SR1.sbn
Boot Load ID 7961G-GE_64-02070631Amd64megRel.bin
Version SCCP41.8-3-2SR1S
Expansion Module 1
Expansion Module 2
Hardware Revision 1.0
Serial Number XXXXXX
Model Number CP-7961G-GE
Message Waiting No
UDI phone
Cisco IP Phone 7961G-GE, Global, Gig Ethernet
CP-7961G-GE
V02
FCH1149AHK6
Time 3:21:57p
Time Zone Eastern Standard/Daylight Time
Date 03/14/08
Burleyman
03-20-2008 02:27 PM
Upgrade the load to latest and CHECK POE. Check -DHCP does not respond or -Corrupt flash, need to reset to factory default to reformat
03-24-2008 06:02 AM
Thanks I will check them out.
Mike
03-24-2008 09:28 PM
Burleyman,
It may well be be your POE switch. Check that and if you have tools run some diagnostics on your cabling/poe switch.
Good luck.
please rate helpful posts.
Baseer.
