ASA enable mode with ACS
Mar 14th, 2008
When I SSH to my ASA is there anyway to go straight to enable mode? We use RSA SecurID which means I have to wait for the token to change before I go into enable mode at the moment.
ASA config:
aaa authentication ssh console CISCO-ACS LOCAL
aaa authentication serial console CISCO-ACS LOCAL
aaa authentication http console CISCO-ACS LOCAL
aaa authorization command CISCO-ACS LOCAL
aaa accounting enable console CISCO-ACS
aaa accounting serial console CISCO-ACS
aaa accounting ssh console CISCO-ACS
aaa accounting command CISCO-ACS
ACS config (Group Level)
Privilege level 15
Read/write command authorisation set
Overall Rating: 5 (1 ratings)
Jagdeep Gambhir Fri, 03/14/2008 - 10:46
Unfortunately that is not possible as ASA does not support Exec Authorization.
Do rate helpful posts
