Alert for Agent Not Ready after missed call
KRISTINE OBrien Fri, 03/14/2008 - 15:19
I would be interested to find out if anyone has a solution as well. Or if there is a way to keep the agent in a ready state if they miss a call.
KRISTINE OBrien Wed, 03/19/2008 - 09:19
Hey Rob,
Those instructions worked...Thanks so much for the help and quick response....
Kristine
david.macias Mon, 03/17/2008 - 14:54
I've never seen one, however if you're using CTIOS you might be able to custom code something that might fit your needs. Additionally, there might be something you can do with a CAD workflow, however I've never tried this either.
david
