invalid power levels?
rygar1234
*Mar 14 18:39:05.555: %DOT11-3-POWERS_INVALID: Interface Dot11Radio0, no valid power levels available
Any idea what this means?
Thank you
7 Replies 7
Scott Fella
Can you provide more info;
LWAPP or IOS
Type of AP
What channel and power setting you have the ap set to.
-Scott
I went in the SDM wireless interface created a new Vlan100 with a SSID MGuest and gave it an ip of 192.168.2.1.
Then I created a DHCP pool for that specific vlan, thats all.
Thank you!
what is the power source of the AP?
Power Supply, PoE (what kind of, poe switch, poe incetor, forign poe device (not Cisco)).
If it is a ios ap and prestd. PoE device (also ASA5505) try
power inline negotiation prestandard source
on the AP.
If it is connected by lwapp to a wlc try:
(Cisco Controller) >config ap power injector ...
Martin
Its a 1811W router running 12.4(15)T4 enterpr. ios i believe.
Thank you
So it has an integrated radio. shouldnt be a power source problem. i am out, didnt know that device.
M.
Thx anyways M
It seems its broken getting a new one fyi
