p2p basic config
Answered Question
Mar 14th, 2008
I have a very basic setup but I guess I am missing something. I am configuring a p2p between 2 locations. I can ping other end router interfaces but not any other devices on the remote networks. I dont need any Internet connectivity but just need between 2 locations.
R1#sh run
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
interface FastEthernet0/0
ip address 172.16.1.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 10.1.0.1 255.255.255.252
encapsulation ppp
service-module 56k clock rate 64
ip classless
ip route 192.168.1.0 255.255.255.0 10.1.0.2
R2#sh run
no aaa new-model
ip subnet-zero
ip cef
duplex auto
speed auto
interface Serial0/0
ip address 10.1.0.2 255.255.255.252
encapsulation ppp
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.10
ip route 172.16.1.0 255.255.255.0 10.1.0.1
Correct Answer by sundar.palaniappan about 8 years 10 months ago
If it's a windows server the remote PCs probably need a WINS server for name resolution. Alternatively, you can use a LMHOST file on the local PC. Have a look at this link.
http://support.microsoft.com/kb/150800
Sundar
Overall Rating: 5 (2 ratings)
sundar.palaniappan Fri, 03/14/2008 - 15:21
1. Are the LAN devices using the correct default gateway address. R1 LAN devices would have to use 172.16.1.1 and R2 LAN devices would have to use 192.168.1.1 as their default gateway.
2. If the default gateway is correct, is ICMP being denied on those hosts. I believe Windows firewall would block ICMP echo replies from being sent. If you can ping the LAN devices from the local router then it would eliminate the possibility of firewall being the issue.
Sundar
techtips03 Fri, 03/14/2008 - 22:00
Hi Sundar
Thanks for the reply. Actually there are 2 ISPs as in the attached network setup. So the default gateway is another router on the same LAN which is 172.16.1.2.
I can ping R3(172.16.1.2) and the server(172.16.1.10) from R1(172.16.1.1) but I cannot ping the same if I give the source interface s0/0(10.1.0.1)
I can ping R1 from R2 and I cannot ping R3.
R2#sh ip route 172.16.1.10
Routing entry for 172.16.1.0/24
Known via "static", distance 1, metric 0 (connected)
Routing Descriptor Blocks:
* directly connected, via Serial0/0, permanent
Route metric is 0, traffic share count is 1
sundar.palaniappan Mon, 03/17/2008 - 08:22
Venkat,
It looks like R3 (Linksys) might be routing all traffic destined to 10.1.0.0/30 and 192.168.1.0/24 to the Internet. You can one of two things
1. add route(s) for these two subnets on R3 to forward traffic to 172.16.1.1(R1)
(or)
2. change the gateway of all PCs to 172.16.1.1 and add a default route on R1 to forward traffic to 172.16.1.2.
Sundar
techtips03 Mon, 03/17/2008 - 10:15
Hi Sundar
Thanks for the reply. I realized this yesterday when I draw the network sent to you. So I added routes below on Linksys
Dest - 10.1.0.0/30
GW - 172.16.1.1
Hop count - 1
Dest - 192.168.1.0/24
GW - 172.16.1.1
Hop count - 3
Now I can ping my server 172.16.1.10 from R2 which is good. However I tried to ping few other devices on the network (eg., 172.16.1.20,21 GW: 172.16.1.2) and I cannot reach them. It doesnt make any sense to me. But I guess these are printers and probably wouldnt bother much about that.
As my R2 location does not have a server, as this p2p in place, can DNS and AD traffic be forwarded over the link?
Also I just configured default route on R1 pointing to R3
Venkat
sundar.palaniappan Mon, 03/17/2008 - 17:27
To transport non-routable (bridged) protocol traffic over the same p2p connection you would have to configure integrated routing & bridging (IRB). This would allow bridged and routed traffic use the p2p connection. DNS uses IP and you should be ok there. What protocol does AD use?
techtips03 Tue, 03/18/2008 - 07:47
For some reason I can ping the server with IP but not with the name from the remote location. I can ping with name from LAN.
I believe AD (Active directory) is IP based. So that should work too right?
Do I need any more configuration on Cisco or Linksys routers to get this working?
Please advise
