MPLS on 2611XM
Mar 14th, 2008
Hello All,
I am trying to run mpls on router 2611xm, but it always returned unrecognized command error.
Is mpls not supported on this platform?.
The machine is loaded with 256/64FLS.
Many thanks in advance
Jon Marshall Fri, 03/14/2008 - 16:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I am running MPLS on some 2621XM's in our lab at work. The IOS i am running is
(C2600-SPSERVICESK9-M), Version 12.3(4)T4
the routers have 128/32 so your's will definitely run it. Not all MPLS functionality is there but they do support MPLS/MPLS VPN/MPLS TE. If you want things lile MPLS FRR (Fast reroute) you need a different router.
The Cisco site does not specifically say the 2621XM is supported so i wouldn't run this in a production environment but it should be okay in a lab.
As i say i am using 2621XM's so i can't definitely say 2611XM would work but i think it probably would.
Jon
