PIX 501 & Remote Client VPN
Mar 14th, 2008
My customer has a pix 501 with a site to site VPN connection to a VPN concentrator at another location, this works fine. I am trying to create a dynamic VPN on the 501 for remote users to connect with laptops/cisco VPN client software. The remote clients can connect to the pix but cannot see the inside network. A "show crypto ipsec sa" command shows the current_peer of my dynamic VPN to be the same as the current_peer of the site to site VPN. Is it possible to have both a site to site VPN and a dynamic VPN running on a pix 501? Thanks in advance.
mvsheik123 Sun, 03/16/2008 - 12:29
Make sure you have spilt-tunneling porperly defiled with your internal networks.
Also, there are few posts related to this kind of issue and also with solutions (configs) in this forum. search for them.
Finally, incae if you still have issues, post clean config of the PIX, and someone will definitely help you.
