qos on a layer2 only subnet
Mar 14th, 2008
I have a layer2 only vlan across different floors on a number of 6500s running IOS, is there a simple way to mark the traffic on that vlan efficiently instead of marking on hundred of ports manually ? Thanks for the input.
Joseph W. Doherty Sat, 03/15/2008 - 06:40
Unsure, what all the 6500 supports, but for L2 only, you might be able to mark on just L2 uplinks. Or, if you are also running L3, mark at the (virtual) gateway interface.
