1+1 APS protection (7600)
Mar 14th, 2008
The following question is posted under “optical networking” which may be better handled here. Can a single, multi-port SPA support APS on the same card or does it require 2 cards in either the same chassis or different chassis? Please answer using the link to the question (provided below):
Thank you
Posted by: sultan-shaikh
Mar 10, 2008, 7:08pm PST
Hi Friends,
The POS SPA for 7600 SPA-2XOC3-POS says that 1+1 APS protection is supported.
Would like to know the implementation, is it per SPA (2 ports in the same SPA) or divided across different SPA ports.
Overall Rating: 4 (1 ratings)
