Downgrading Cisco PIX
Mar 15th, 2008
Hi All,
i was reading the config guide for the Cisco PIX Version 6.3 IOS, i noticed there is no clear procedure for downgrading the cisco pix from this version to version 6.0.
there is a procedure for downgrading to version 4 and 5.
here is what in the config PDF: "To downgrade to an earlier version, enter the following command:
flash downgrade version
Replace version with one of the following values:
•4.2
•5.0
•5.1
You do not need to use the flash downgrade command when downgrading to Versions 5.2 or 5.3 from Version 6.1."
please how can i go with the downgrade to version 6.0. i need this procedure if the version 6.3 fails?!!!
regards,
Ala
abinjola Sat, 03/15/2008 - 03:11
  • Cisco Employee,
use the procedure,
copy tftp flash
jojuarez Sat, 03/15/2008 - 19:25
Hi Ala,
You can just use the "copy tftp flash" command and just upload the old image. You can refer to the following link:
http://cco.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_61/relnotes/61dwngrd.htm
Although I do not know why would someone want to go to versions earlier than 6.3.5 as they're no longer supported.
In the odd case that you encounter any problem w/ 6.3.5 (which, btw, is GD), you may go for an interim release but not to downgrade. v6.3.5 has several fixes for bugs in earlier deployments.
Amahameed Sat, 03/15/2008 - 23:06
Hi jojuarez,
Actually, just to know, and as a pre-caution.
thanks for help.
