WiSM Custom Internal Auth SSL
Answered Question
Mar 15th, 2008
We're using custom internal auth on our new WiSM and it works great.
The only issue we have is that the self signed certificate prompts warning messages for the user before they can authenticate. We need to avoid this and are looking to get a proper certificate to replace it.
The web page appears to come from the virtual interface - in our case 1.1.1.1
a) is it possible to get a certificate from a certificate authority for this IP address?
b) can the same certificate be used on both controllers within the blade - or will it need two seperate ones?
c) To get a certificate I need to get the CSR to submit, but I can't find it?
Philip
Correct Answer by Scott Fella about 9 years 4 months ago
You need a certificate that is trusted in your cert store. You might try to look at this. RapidSSL is one that I use alot.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00806e367a.shtml
Overall Rating: 5 (1 ratings)
Correct Answer
Scott Fella Sun, 03/16/2008 - 08:09
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
