IMlA Interface problem
I have a problem with my ATM/IMA subinterfaces in that I can't even ping my local interface from the router despite it showing UP UP.
I am connecting to 3 times E1's using VWIC2 mutliflex cards on a 3825.
I have an ATM aim model and all of the above seem to be up OK.
I am working with my telco to connect remote frame-relay sites in to my core site.
The remote sites stay as frame-relay and my core site has 3 times E1's connected to my telco's ATM switch (a Nortel) as a single 6 meg ATM bundle.
We are trying to migrate my core site from frame-relay to ATM over E1 using the configuration below.
My IMA is UP, and my sub-interfaces are UP UP, but I can't ping my local sub-interface IP address, let alone the remote site IP.
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-participate aim 0
network-clock-select 1 E1 0/0/0
controller E1 0/0/0
mode atm aim 0
framing NO-CRC4
controller E1 0/0/1
mode atm aim 0
framing NO-CRC4
controller E1 0/1/0
mode atm aim 0
framing NO-CRC4
interface ATM0/0/0
bandwidth 2048
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
scrambling-payload
ima-group 1
no atm ilmi-keepalive
interface ATM0/0/1
bandwidth 2048
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip mroute-cache
no snmp trap link-status
scrambling-payload
ima-group 1
interface ATM0/1/0
bandwidth 2048
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
scrambling-payload
ima-group 1
interface ATM0/IMA1
bandwidth 6144
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
interface ATM0/IMA1.2 point-to-point
description ATM Connection to Desforge Branch
bandwidth 512
ip address xx.xx.xx.xx xx.xx.xx.xx
no ip redirects
no ip unreachables
no ip proxy-arp
no routing dynamic
pvc 4/101
oam-pvc manage
encapsulation aal5snap
interface ATM0/IMA1.10 point-to-point
description test link to QB DR
bandwidth 64
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 3/120
no oam-pvc manage
interface ATM0/IMA1.13 point-to-point
description PVC to Chemin Grenier Branch
bandwidth 128
no ip redirects
no ip unreachables
no ip proxy-arp
ip mroute-cache
pvc 4/126
Am I missing some command to map my layer 3 to the layer 2 protocol?
Any other ideas?
paolo bevilacqua Sat, 03/15/2008 - 09:42
  • Hall of Fame,
    Founding Member
check if the cell counters are increasing with: show atm pvc x/y. On the remote do the same, but is show frame-relay instead. Check the remote likely must use encapsulation frame-relay ietf for this to work.
If the counters are not increasing, telco has not provisioned the IWF correctly.
Note unrelate to the issue, the following commands:
bandwidth xxx
no ip redirects
no ip proxy-arp
are not doing anything and can be removed.
strangely, the test link we configured last night suddenly started working, however telco insists he did nothing!!
But today we tried to configure another site and now, although we can ping the local IP;s on the ima subinterfaces, we can't ping the remotes an the pvc that was working or on the new one!
Have triede router reloads and modem resets etc, all to no avail.
The counters are increasing on both ends as per the sho outputs below:
rwmabellv0102#sho atm pvc 3/120
Description: N/A
ATM0/IMA1.11: VCD: 6, VPI: 3, VCI: 120
UBR, PeakRate: 5760 (13585 cps)
AAL5-LLC/SNAP, etype:0x0, Flags: 0xC20, VCmode: 0x0, Encapsize: 12
OAM frequency: 0 second(s), OAM retry frequency: 1 second(s)
OAM up retry count: 3, OAM down retry count: 5
OAM Loopback status: OAM Disabled
OAM VC Status: Not Managed
ILMI VC status: Not Managed
InARP frequency: 15 minutes(s)
Transmit priority 4
InPkts: 49, OutPkts: 38, InBytes: 5364, OutBytes: 3672
InPRoc: 23, OutPRoc: 20, Broadcasts: 18
InFast: 26, OutFast: 0, InAS: 0, OutAS: 0
InPktDrops: 0, OutPktDrops: 0/0/0 (holdq/outputq/total)
CrcErrors: 0, SarTimeOuts: 0, OverSizedSDUs: 0, LengthViolation: 0, CPIErrors: 0
Out CLP=1 Pkts: 0
OAM cells received: 0
F5 InEndloop: 0, F5 InSegloop: 0, F5 InAIS: 0, F5 InRDI: 0
F4 InEndloop: 0, F4 InSegloop: 0, F4 InAIS: 0, F4 InRDI: 0
OAM cells sent: 0
F5 OutEndloop: 0, F5 OutSegloop: 0, F5 OutRDI: 0
F4 OutEndloop: 0, F4 OutSegloop: 0, F4 OutRDI: 0
OAM cell drops: 0
Status: UP
VC 3/120 doesn't exist on 3 of 4 ATM interface(s)
QBornes_DR_Site_RTR01#sho frame-relay pvc 100
PVC Statistics for interface Serial0 (Frame Relay DTE)
DLCI = 100, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0.101
input pkts 83 output pkts 165 in bytes 7552
out bytes 17918 dropped pkts 0 in pkts dropped 0
out pkts dropped 0 out bytes dropped 0
in FECN pkts 0 in BECN pkts 0 out FECN pkts 0
out BECN pkts 0 in DE pkts 0 out DE pkts 0
out bcast pkts 12 out bcast bytes 4344
pvc create time 00:08:22, last time pvc status changed 00:07:23
We did have to change the IOS on our local router as we had to install an additional FastEthernet NM module and the IOS would not recognise it, could this be related?
Old and new IOS versions shown below:
original ver: c3825-advipservicesk9-mz.124-11.T4.old
current ver: c3825-advipservicesk9-mz.124-9.T4.bin
paolo bevilacqua Sun, 03/16/2008 - 05:56
  • Hall of Fame,
    Founding Member
Hi can you ask telco if they're are doing transparent or translated iwf ?
Can you send interface config the the FR side?
For the NM, send output of show diag.
paolo bevilacqua Sun, 03/16/2008 - 07:56
  • Hall of Fame,
    Founding Member
Ok. The NM-1E hat you're trying is not supported in the ISR router, get HWIC-1FE or 2FE.
OK, but we did try a HWIC-1FE first with the same result.
Also, forgot to add the remote router frame-relay i/f config, so here it is:
Note s0.1 and s0.2 are on existing frame-relay network and work OK (have been in use for a number of years)
s0.101 is on the new dlci that connects into the telco's frame to ATM network
interface Serial0
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type q933a
interface Serial0.1 point-to-point
description Live Link to Quatre Bornes
bandwidth 32
ip address xx.xx.xx.xx 255.255.255.252
ip access-group 151 in
ip ospf network non-broadcast
frame-relay interface-dlci 17
crypto map qb_dr_live
interface Serial0.2 point-to-point
description backup Link to Bell Village
bandwidth 16
frame-relay interface-dlci 16
crypto map qb_dr_back
interface Serial0.101 point-to-point
frame-relay interface-dlci 100
