HSRP Interface Problem
Mar 15th, 2008
I have confiugred the MHSRP successfully. I am able to provide the redundency and load balancing. But problem is that I am not able to track the Interface connected with WAN.
It is ethernet interface and I mentioned it in HSRP configration, but when it goes down, it is not detected by HSRP.
Below mention is the configuration of HSRP
interface GigabitEthernet0/1
ip address 13.1.1.6 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
standby 1 ip 13.1.1.4
standby 1 priority 150
standby 1 preempt
standby 1 track GigabitEthernet0/0
standby 2 ip 13.1.1.8
standby 2 preempt
standby 2 track GigabitEthernet0/0
Kindly help me out, how to solove this problem. Anyway to configure tracking any other method, if yes then how to configure that method. Why not it is working with HSRP.
Edison Ortiz Sat, 03/15/2008 - 08:58
  • Hall of Fame,
    Founding Member
Configure SLA with ICMP Echo to the next-hop by following this document:
http://www.cisco.com/en/US/docs/ios/12_4/ip_sla/configuration/guide/hsicmp.html
Once the SLA is configured, verify the track goes down when the link fails.
Attach the track to the MHSRP configuration along with a decrement value. Currently, I don't see any decrement on the standby 1 track GigabitEthernet0/0 command.
Here is a good example of using track along with HSRP
http://www.cisco.com/en/US/docs/ios/12_4/ip_appl/configuration/guide/haipbtrk.html#wp1184322
HTH,
__
Edison.
wasiimcisco Sat, 03/15/2008 - 11:36
Thanks for the reply, I made a track for outside interface and it works.
Now i am able to load balance and also getting redundency.
Thank you so much.
