Vlan IOS switch commands question
Mar 15th, 2008
Hello, I am having issues understanding what commands are used for vlan configuration on the CCNA. Boson simulations uses old commands and the TV Videos uses other ones, do you know which ones are the ones that work in the current CCNA exam? Thank you in advance
scottmac Sat, 03/15/2008 - 16:21
I just did a re-cert for CCNP (BCMSN), and the questions / SIMs included a phrase "since 'VLAN Database' is being deprecated, use global config mode"
Plan on using global config mode (i.e., DO NOT go to vlan database to create the vlans or modify the VTP domain or modes).
Good Luck
Scott
Pravin Phadte Wed, 03/19/2008 - 05:57
I would agree with scottmac.
please try to avoid the vlan database commnad in the real world also unless the ios does not suppport you to create vlan from global config mode.
best of luck
