simple issue ... but strange
Manoj Wadhwa
Hi Friends,
We commissioned a new Leased Line from one of the Telco's to serve as a backup. But we are running into an issue which seems to be strange ... we are unable to identify if this is a Telco issue or something at our end. Basically, the LL is connected, the interface status at both the ends is showing as Up & Up but we are not even able to ping from one end to another. There are no blocking policies. Please help to identify if you have experience such issue as per your experience. Thanks!
TEST1#ping ip X.X.X.42 source X.X.X.41
Sending 5, 100-byte ICMP Echos to X.X.X.42, timeout is 2 seconds:
Packet sent with a source address of X.X.X.41
Success rate is 0 percent (0/5)
TEST1#show arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet X.X.X.42 0 Incomplete ARPA
TEST1#show int gi0/0
GigabitEthernet0/0 is up, line protocol is up
Hardware is BCM1125 Internal MAC, address is 0016.c79b.5ea0 (bia 0016.c79b.5ea0)
Internet address is X.X.X.41/30
MTU 1500 bytes, BW 20480 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is RJ45
output flow-control is XON, input flow-control is XON
Last input 1d16h, output 00:00:07, output hang never
Last clearing of "show interface" counters 3d11h
Queueing strategy: fifo
Output queue: 0/40 (size/max)
3797 packets input, 530664 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 0 multicast, 0 pause input
59936 packets output, 6177065 bytes, 0 underruns
1 output errors, 0 collisions, 6 interface resets
1 lost carrier, 0 no carrier, 0 pause output
TEST2#show int fa1/1
FastEthernet1/1 is up, line protocol is up
Hardware is AmdFE, address is 0009.b7a1.3992 (bia 0009.b7a1.3992)
Internet address is X.X.X.42/30
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 1d15h, output 00:00:05, output hang never
Queueing strategy: custom-list 1
Output queues: (queue #: size/max/drops)
0: 0/20/0 1: 0/20/0 2: 0/20/0 3: 0/20/0 4: 0/20/0
5: 0/20/0 6: 0/20/0 7: 0/20/0 8: 0/20/0 9: 0/20/0
10: 0/20/0 11: 0/20/0 12: 0/20/0 13: 0/20/0 14: 0/20/0
15: 0/20/0 16: 0/20/0
65051 packets input, 31706615 bytes
Received 953 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
64491 packets output, 12068478 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
0 lost carrier, 0 no carrier
Manoj
7 Replies 7
Danilo Dy
Is this a P2P MetroE Line?
Dandy
Hi Danny,
Thanks for your response. It is not a MetroE line. A simple LL connectivity like a typical LL.
I think this has to do with the telco,verify how their internal connections are setup which are connecting u r sites.
Mahmood
Hi Manoj,
Can I know wt is the outbound interface . Ru using any modems.
Mohan
Hi Mohan,
The fast ethernet port is connected to a ethernet/ fiber convertor .... from here there is a fiber to connect to the other end .. where again there is a fiber/ ethernet convertor connecting back to the gigabit ethernet port ...
Manoj
Do yourself a favor, buy two cisco SFPs mated to the type of fiber you have. Converters are a notorious source of fault and frustration.
Also note, after you''l have that working, it's pointless that you try custom queuing on a gigaethernet interface, as in most cases, these are never congested.
The convertors are given by our providers, hence i guess it is upto them to decide on what they would like to use. Anyways, they are going to do some kind of testing tomorrow noon and if things still do not work, i will certainly put forward the suggestion you gave to them. I will let you all know how things proceed tomorrow. Until then, take care and thanks for your replies.
Best Regards,
Manoj
