Joe Clarke Sun, 03/16/2008 - 10:00
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The symbols come as part of the network management integration database which is used by the CiscoWorks Integration Utility and Adapter to register MIBs and symbols with various third party NMS applications. While using the database without CiscoWorks is not supported, you should be able to extract the MIBs and symbols from it. It can be downloaded from http://www.cisco.com/cgi-bin/Software/Tablebuild/doftp.pl?ftpfile=/cisco/netmgmt/ciscoview/5.0/packages/nmidb.1.0.089.zip&app=CVPlanner&status=showC2A .
