LMS 3.0 software distribution on Catalysts with .tar files?
Mar 16th, 2008
  • Gold, 750 points or more
Does LMS 3.0 allow software distribution using .tar files? for example to manually upgrade a Catalyst 3560 you can either just copy the .bin IOS image or you can use the 'archive download-sw...' command to copy & extract the IOS image and the HTML files from the .tar image. Is this possible with LMS 3.0 via software distribution?
I had a quick search and can only see the ability to import and distribute IOS .bin files?
Joe Clarke Sun, 03/16/2008 - 09:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, LMS allows distribution of .tar files. Some devices (e.g. 3750 stacks) require .tar images, and one cannot distribute .bin images to them.
