ohassairi Sun, 03/16/2008 - 10:54
  • Silver, 250 points or more
use kiwisyslog simple and free
cisco24x7 Sun, 03/16/2008 - 11:07
syslog-ng is very granular and you can specify
separate locations for each devices.
Furthermore, you can dump this into mySQL for
mining and analysis later.
i don't think Kiwi can do that and even if it
does, it requires MS SQL server for that which
is not free.
munawar.zeeshan Sun, 03/16/2008 - 14:45
Can i get the direct link for, PIX Firewall Manager (PFM) and/or PIX Firewall Syslog Server (PFSS).
francisco_1 Sun, 03/16/2008 - 15:28
  • Gold, 750 points or more
I have tried to locate the direct link on the cisco website but cant find either. if you can find it i am happy to use my CCO to download it for you.
good luck.
Franco
francisco_1 Sun, 03/16/2008 - 15:30
like i said before syslog-ng will do what you want. we use it for our cisco devices, routers, switches and firewalls
scristian Mon, 03/17/2008 - 04:05
With syslog-ng
In syslog-ng.conf you put something like this
destination ra1 { file("/logging/sw/ra1"); };
filter f_ra1 { host(ip_ra1); };
log { source(net); filter(f_ra1); destination(ra1); };
and on cisco switch you put smth like this
#snmp-server enable traps syslog
