Crypto Map ignoring traffic from vrf
Mar 16th, 2008
Hi all,
I have a problem with a configuration using crypto maps and vrf-lite.
My router has 3 logical interfaces
- two of them (WAN_GLOBAL, LAN_GLOBAL) belong to the global routing table
- one (LAN_VRF) belongs to a VRF MyVRF
Interesting addresses in MyVRF (behind interface LAN_VRF) are statically natted to global routing table addresses so that communication is possible between the global routing table and the VRF. This configuration is working fine.
Unfortunately in my scenario all the traffic coming from a VRF natted address and going to a remote destination needs to be tunneled using IPsec to a remote peer so I added a crypto map to the WAN_GLOBAL interface.
The problem is that the router completely ignores all traffic originated behind the VRF interface even if a matching access-list entry is associated with the crypto map. All other interesting traffic originated behing global routing table interfaces is correctly matched and encrypted.
It seems that packets coming from a vrf interface are treated differently even after they have been "moved" to the global routing table and natted.
Is this an unexpected behaviour or I'm missing something?
The configuration I used is a classic crypto map configuration like this :
! *** Incomplete configuration ***
ip access-list ext VPN
! Interesting traffic from a global routing table interface
permit ip host host ! ... this works
! Interesting traffic from the VRF interface
! (source address is the NAT address not the original VRF address)
permit ip host host ! ... this one is not matched
crypto isakmp key ... address ...
crypto map CM perm 10 ipsec-isakmp
set peer ...
set transform-set TS
match address VPN
interface <WAN_GLOBAL>
ip nat outside
crypto map CM
interface <LAN_VRF>
ip nat inside
ip vrf forwarding MyVRF
Thank you very much in advance for your help.
