Is it possible to log CLI without tacacs?
Answered Question
Mar 16th, 2008
I am curious to know if it is possible to log user command line actions on Cisco devices, without having a tacacs server.
Correct Answer by cisco24x7 about 9 years 2 months ago
archive
log config
logging enable
notify syslog
hidekeys
Overall Rating: 5 (1 ratings)
cisco24x7 Sun, 03/16/2008 - 13:50
  • Silver, 250 points or more
yes, starting with IOS version either 12.3 or
12.3T, you can log user command via syslog.
I implemented this feature on my production
router with IOS 12.4(16) IP Advanced services
I will post the configuration for you tomorrow.
CCIE Security
Correct Answer
cisco24x7 Sun, 03/16/2008 - 16:29
archive
log config
logging enable
notify syslog
hidekeys
Jason Fraioli Sun, 03/16/2008 - 17:49
Fantastic! Thanks so much.
Edit. Does this functionality require advanced IP services, or will this work on IP services with crypto?
Jason Fraioli Mon, 03/17/2008 - 05:57
One last question pertaining to logging. Is there a way to limit the interfaces UP/DOWN informationals being syslogged? In Kiwi Syslog the interface informational messages show up as Level7.Notice for the protocol and Level7.Error for the link. Is there a way to just filter out the link/protocol informationals and allow all others?
Thanks in advance
